Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S8 Active Rear-Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, SIM Tray/Card: étape 1, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, SIM Tray/Card: étape 1, image 2 de 2
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, NFC Antenna and Charging Coil Assembly: étape 2, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, NFC Antenna and Charging Coil Assembly: étape 2, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, NFC Antenna and Charging Coil Assembly: étape 2, image 3 de 3
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
    Demander à FixBot
  3. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 3, image 1 de 1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    Demander à FixBot
  4. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 4, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 4, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 4, image 3 de 3
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
    Demander à FixBot
  5. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 5, image 1 de 1
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
    Demander à FixBot
  6. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 6, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 6, image 2 de 2
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
    Demander à FixBot
  7. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 7, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 7, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 7, image 3 de 3
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
    Demander à FixBot
  8. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 8, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 8, image 2 de 2
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
    Demander à FixBot
  9. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Loudspeaker Assembly: étape 9, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Loudspeaker Assembly: étape 9, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Loudspeaker Assembly: étape 9, image 3 de 3
    • Remove the loudspeaker assembly using the flat end of a spudger.
    Demander à FixBot
  10. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Front-Facing Camera: étape 10, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Front-Facing Camera: étape 10, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Front-Facing Camera: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    • Disconnect the front-facing camera flex cable from the motherboard using the flat end of a spudger.
    • Use tweezers to gently lift the camera from its slot.
    Demander à FixBot
  11. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Iris Scanner: étape 11, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Iris Scanner: étape 11, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Iris Scanner: étape 11, image 3 de 3
    • Disconnect the iris scanner flex cable from the motherboard using the flat end of a spudger.
    • Use tweezers to gently lift the iris scanner from its slot.
    Demander à FixBot
  12. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Motherboard: étape 12, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Motherboard: étape 12, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Motherboard: étape 12, image 3 de 3
    • Disconnect the battery flex cable using the flat end of a spudger.
    Demander à FixBot
  13. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 13, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 13, image 2 de 2
    • Remove one 3.5 mm screw using a Phillips #00 Screwdriver.
    Demander à FixBot
  14. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 14, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 14, image 2 de 2
    • Disconnect the Volume Up, Volume Down, and Bixby button flex cable using the flat end of a spudger.
    Demander à FixBot
  15. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 15, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 15, image 2 de 2
    • Disconnect the display flex cable using the flat end of a spudger.
    Demander à FixBot
  16. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 16, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 16, image 2 de 2
    • Disconnect the charging port flex cable using the flat end of a spudger.
    Demander à FixBot
  17. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 17, image 1 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 17, image 2 de 3 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 17, image 3 de 3
    • Disconnect the black and white antenna cables using the flat end of a spudger.
    Demander à FixBot
  18. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 18, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 18, image 2 de 2
    • The motherboard rests on top of the daughterboard, and there is a flex cable connecting them. Disconnect the flex cable that connects the motherboard to the daughterboard using the flat end of a spudger.
    Demander à FixBot
  19. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 19, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 19, image 2 de 2
    • Position the flat end of a spudger at the top edge of the motherboard.
    • Carefully pry up and remove the motherboard.
    Demander à FixBot
  20. Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Rear-Facing Camera: étape 20, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement, Rear-Facing Camera: étape 20, image 2 de 2
    • Turn the motherboard over so that the rear-facing camera is face down.
    • Disconnect the camera's flex cable using the spudger.
    Demander à FixBot
  21. Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 21, image 1 de 2 Samsung Galaxy S8 Active Rear-Facing Camera Replacement: étape 21, image 2 de 2
    • Flip the motherboard back over.
    • Pop the camera out of its socket using your fingers or the flat end of a spudger.
    • When removing the camera with your fingers, make sure you do not put too much bending pressure on the rest of the motherboard or else it may break.
    • If you choose to just use your fingers (which was actually the easier way to do it), make sure your avoid touching the lens of the new camera. Otherwise, you will have blurry pictures with your new camera!
    Demander à FixBot
3 autres ont terminé cette réparation.
Erik Mauk
Membre depuis le 01/24/19
1 519 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S2-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S2-G1, White Winter 2019
CPSU-WHITE-W19S2G1
3 membres
22 tutoriels rédigés
3 commentaires de tutoriel
I need a rear facing camera for my samsung galaxy s8 active. Sm-g892a. Do you sell the camera or do you know where I can buy a new one?
Justin Rauch - Réponse Partager
So I took this apart and either the camera is shot itself (unsure how to determine) or is it possible a ripped finger print scanner ribbon could somehow disable the camera from working? I can't imagine so but I was curious and wanted to ask since your site has helped me TONS on repairs at home. Thanks!
Tyler Giacchino - Réponse Partager
I dont have a fingerprint sensor and my cam works perfectly fine. G892A
i broke it by opening backdoor and breaking ribbon
David Dibean Jr - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 52
Total : 2,586
