Introduction
Use this guide to remove the earpiece speaker in your Samsung Galaxy S8.
This guide involves removing the rear glass cover, you will need replacement adhesive to reattach the back cover to the phone.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Ce dont vous avez besoin
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove eleven 3.7 mm screws using a Phillips #000 screwdriver.
Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
Press to eject the tray.
Remove the SIM card tray from the phone.
Use the flat end of a spudger to disconnect the battery connector.
Use the flat end of a spudger to disconnect the sensor array connector.
Insert the pointed end of a spudger into the small slot on the side of the earpiece speaker. Use the spudger to pry the speaker out of its slot.
Remove the earpiece speaker.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
After you've completed the repair, follow this guide to test your repair.
24 autres ont terminé cette réparation.
2 commentaires
Under the “parts” section it lists Galaxy S8 Rear Cover Adhesive. Isnt that for the regular s8? Is there a version for the s8 plus??
Hi David, we don’t yet carry rear cover adhesive strips for the S8+—I’d recommend using a strong double-sided tape, like Tesa 61395 tape. If you’re working on an S8+, we also have a set of guides specifically for that here. Good luck with your repair!
