Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung Galaxy S8, utilisez notre manuel de réparation.
  1. Samsung Galaxy S8 Teardown, Samsung Galaxy S8 Teardown: étape 1, image 1 de 3 Samsung Galaxy S8 Teardown, Samsung Galaxy S8 Teardown: étape 1, image 2 de 3 Samsung Galaxy S8 Teardown, Samsung Galaxy S8 Teardown: étape 1, image 3 de 3
    • Samsung seems to have gone all-out to provide the same smartphone experience regardless of your screen size preferences, and the Galaxy S8's specs bear that out. Any of this look familiar?
    • 5.8-inch, dual-edge, Super AMOLED display with 2960 × 1440 resolution (570 ppi)
    • Qualcomm Snapdragon 835 or Samsung Exynos 8895 processor, with 4 GB RAM
    • 12-megapixel rear camera with dual pixel autofocus and 4K video capture; 8-megapixel selfie camera
    • 64 GB internal storage, expandable via MicroSD card (up to 256 GB additional)
    • IP68 water resistance rating
    • Android 7.0 Nougat
  2. Samsung Galaxy S8 Teardown: étape 2, image 1 de 3 Samsung Galaxy S8 Teardown: étape 2, image 2 de 3 Samsung Galaxy S8 Teardown: étape 2, image 3 de 3
    • Dimensions aside, the S8 fairly identically clones the look of the S8+. Features include:
    • Speaker grille and microphone hole
    • USB-C charging port and headphone jack (Apple: 0 Samsung: 1)
    • Pulse reader/flash assembly
    • Rear-facing camera
    • Fingerprint reader
    • The S8 is a safe evolution on the S7 Edge—proportions, camera and sensor package location, and size are all fairly on par.
  3. Samsung Galaxy S8 Teardown: étape 3, image 1 de 3 Samsung Galaxy S8 Teardown: étape 3, image 2 de 3 Samsung Galaxy S8 Teardown: étape 3, image 3 de 3
    • The Galaxy once again rocks the glass-on-glass design, making our lives difficult. We heat the heck out of this panel and apply plenty of prying picks.
    • Once we get an edge open, the iSclack helps us crank through the rest of the gnarly adhesive (which will need replacing upon reassembly—*groan*).
    • And we're in—to an S8+? This guy looks pretty darn identical.
  4. Samsung Galaxy S8 Teardown: étape 4, image 1 de 2 Samsung Galaxy S8 Teardown: étape 4, image 2 de 2
    • The fingerprint sensor lives in the rear case, somewhat controversially placed. Using the thing (with your right hand) requires blindly stretching and blotting out the camera...
    • The good news is that this sensor is modular and can be popped right off its adhesive for replacement. All it takes is a little heat and a good push.
    • No word (yet) whether software locks (à la iPhone 7) will prevent a replacement from functioning.
  5. Samsung Galaxy S8 Teardown: étape 5, image 1 de 1
    • As with its S8+ sibling, the S8 employs some sweet hardware multitasking. The speaker/antenna array, and antenna/NFC coil assembly, do double duty as the phone's midframe.
    • Also like the S8+, the NFC antenna presumably does an additional job, spoofing MST to use Samsung Pay at any card reading checkout location.
    • We're almost running out of things to say here—the rest of the phone looks pretty much like the S8+ too, down to the wee pancake vibrator. It's like someone left the S8+ in their pocket on laundry day and it came out of the wash slightly shrunken, but no worse for wear.
  6. Samsung Galaxy S8 Teardown: étape 6, image 1 de 3 Samsung Galaxy S8 Teardown: étape 6, image 2 de 3 Samsung Galaxy S8 Teardown: étape 6, image 3 de 3
    • You'd think that after Samsung's less than stellar battery record, they'd have a quick eject system for these little bombs packs. And yet, this cell is firmly (and we mean firmly) adhered.
    • And it's not like it's especially hard to have a removable battery—it's done all over the phone world.
    • The Samsung-branded battery clocks in at 11.55 Wh—comparable to the Google Pixel's 10.66 Wh, but dwarfing the (slightly smaller) iPhone 7's 7.45 Wh battery.
    • The capacity comparison may look impressive, but reports seem to suggest that the actual performance is nothing to cheer about.
  7. Samsung Galaxy S8 Teardown: étape 7, image 1 de 3 Samsung Galaxy S8 Teardown: étape 7, image 2 de 3 Samsung Galaxy S8 Teardown: étape 7, image 3 de 3
    • The I/O board connector is under the motherboard in these late-model Galaxy phones. Because why not make things harder?
    • The motherboard itself pops out with relative ease, giving us a peep at that now-Samsung-standard heatpipe.
    • The I/O daughterboard configuration matches the S8+ right down to the modular headphone jack.
    • Since we've already gone through the camera shenanigans, let's get straight to the chips.
  8. Samsung Galaxy S8 Teardown: étape 8, image 1 de 1
    • We checked the genetics chips in the S8 to see if it is truly a smaller twin of the S8+:
    • Samsung K3UH5H50MM-NGCJ 4 GB LPDDR4 RAM layered over the MSM8998 Snapdragon 835
    • Toshiba THGBF7G9L4LBATR 64 GB UFS (NAND flash + controller)
    • Qualcomm WCD9341 Aqstic audio codec
    • Skyworks SKY78160-11 WLAN front end module
    • Avago AFEM-9066 power amplifier module
    • NXP Semiconductor PN80T NFC controller w/ secure element
    • Silicon Mitus SM5720 interface PMIC
  9. Samsung Galaxy S8 Teardown: étape 9, image 1 de 1
    • On the opposite side we find:
    • Murata KM6D28040 Wi-Fi Module
    • Qualcomm PM8998 (similar to PM8920) Power Management
    • Qualcomm WTR5975 RF Transceiver
    • Avago AFEM-9053 power amplifier (likely)
    • IDT P9320S wireless power receiver
    • Maxim MAX77838 companion PMIC (similar to MAX77829) (for AMOLED displays)
    • Samsung S59X7P1 image processor (likely)
  10. Samsung Galaxy S8 Teardown: étape 10, image 1 de 2 Samsung Galaxy S8 Teardown: étape 10, image 2 de 2
    • IC Identification, pt. 2:
    • RDA Microelectronics RDA6213N FM transceiver (likely)
    • Skyworks SKY13716-11 low band LNA front end module
    • Qualcomm ? D5319 mid-band diversity
    • Qualcomm ? D5320 high-band diversity (likely)
    • Skyworks SKY77365-11 power amplifier module
    • NXP Semiconductor BGU8103 GPS/GLONASS/Galileo/BeiDou Low Noise Amplifier
    • NXP Semiconductor PCAL6524 24-bit I/O expander
  11. Samsung Galaxy S8 Teardown: étape 11, image 1 de 2 Samsung Galaxy S8 Teardown: étape 11, image 2 de 2
    • IC Identification, pt. 3:
    • Maxim MAX98506 audio amplifier
    • Qualcomm PM8008 power management
    • Samsung S2MPB02 power management
    • Samsung S2MM005X02 USB power delivery controller (likely)
    • ON Semiconductor FPF3688UCX load switch
    • ON Semiconductor FAN48618 voltage regulator and Richtek RT8010GQW 1 A DC/DC converter
    • Vishay DG2730 2 port, 480 Mbps DPDT USB 2.0 analog switch and NXP Semiconductor NCX2200 comparator
  12. Samsung Galaxy S8 Teardown: étape 12, image 1 de 2 Samsung Galaxy S8 Teardown: étape 12, image 2 de 2
    • IC Identification, pt. 4 (sensors):
    • STMicroelectronics LSM6DSL 3-axis accelerometer/gyroscope
    • STMicroelectronics LPS22HB Pressure Sensor
    • AKM Semiconductor AK09916C 3-axis electronic compass
    • Ablic (formerly Seiko Instruments) S-5712CCDL1-I4T1U Hall Effect Sensor
    • Semtech SX9320 Proximity Sensor (likely)
    • Analog Devices ? Heart Rate Sensor
  13. Samsung Galaxy S8 Teardown: étape 13, image 1 de 1
    • That's it for the vanilla S8. If you haven't already guessed, we've got a more detailed breakdown of the S8+, so check it out if you haven't already.
    • With that, let's give the Galaxy S8 its repairability score.
  14. Dernières pensées
    • Lots of components are modular and can be replaced independently.
    • The battery can be replaced, but tough adhesive and a glued-on rear panel make it unnecessarily difficult.
    • Front and back glass make for double the crackability, and strong adhesive on both makes it tough to access the internals for any repair.
    • Because of the curved screen, replacing the front glass without destroying the display is extremely difficult.
    Indice de réparabilité
    4
    Indice de réparabilité de 4 sur 10
    (10 étant le plus facile à réparer)
41 commentaires de tutoriel
With the release of the Samsung Galaxy S8 and S8+, Samsung has begun building new "Wizard Lounges" at which Samsung officials can personally tell you "your phone is broken, buy a new one!"
George A. - Réponse Partager
+1 for the best review I have seen on this so far.
Kendall Paisley - Partager
Very nice Photography!
Tecnopolis Magazine - Réponse Partager
I would like to know how heavy the battery is compared with the S7 battery and how big (volume) it is
Henning Holthusen - Réponse Partager
From memory, (did a teardown just recently,) the S8 Battery is significantly heavier than an S7 battery. It is quite a bit thinner however, so the added weight must be caused by the internals. I'm no expert on battery composition but I know for sure that S8 batteries are much more durable from a repairers point-of-view.
Harry Rowse - Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 66
30 derniers jours : 361
Total : 315,140
