Aller au contenu principal
Samsung Galaxy S9 Fingerprint Sensor Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Samsung Galaxy S9 Fingerprint Sensor Replacement, Rear Glass Removal: étape 1, image 1 de 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
    • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 2, image 1 de 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 3, image 1 de 3 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 3, image 2 de 3 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 3, image 3 de 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap you created and slide it to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
  4. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 4, image 1 de 2 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 4, image 2 de 2
    • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
    • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
  5. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 5, image 1 de 3 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 5, image 2 de 3 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 5, image 3 de 3
    • Slide the opening pick from the bottom right corner along the side to the top.
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
    • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
  6. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 6, image 1 de 2 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 6, image 2 de 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  7. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 7, image 1 de 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
  8. Samsung Galaxy S9 Fingerprint Sensor Replacement, Fingerprint Sensor: étape 8, image 1 de 1
    • Heat up the iOpener in the microwave for 30-60 seconds.
    • Place the iOpener on the back cover for 2-3 minutes to heat up the adhesive holding the fingerprint sensor.
    • The iOpener may still be warm from earlier steps. You may not need to microwave it again.
  9. Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 9, image 1 de 3 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 9, image 2 de 3 Samsung Galaxy S9 Fingerprint Sensor Replacement: étape 9, image 3 de 3
    • Carefully slide the Jimmy under the fingerprint sensor.
    • Peel off the fingerprint sensor from the back cover.
Jonne Vicario
Membre depuis le 01/24/19
509 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G6, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G6, White Winter 2019
CPSU-WHITE-W19S1G6
4 membres
29 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,978
