Aller au contenu principal
Samsung Galaxy SIII Mini Display Assembly Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: étape 1, image 1 de 2 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: étape 1, image 2 de 2
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 2, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 2, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 2, image 3 de 3
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 3, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 3, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 3, image 3 de 3
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 4, image 1 de 1
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 5, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 5, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 5, image 3 de 3
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 6, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 6, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 6, image 3 de 3
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 7, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 7, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 7, image 3 de 3
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 8, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 8, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 8, image 3 de 3
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 9, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 9, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 9, image 3 de 3
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 10, image 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 10, image 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: étape 10, image 3 de 3
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: étape 11, image 1 de 1
    • That's all.
    • Did you do it successfully?
18 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
192 056 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 525 tutoriels rédigés
2 commentaires
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - Réponse
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 17,550
