Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy SIII Mini VE Front Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: étape 1, image 1 de 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: étape 1, image 2 de 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: étape 1, image 3 de 3
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: étape 2, image 1 de 2 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: étape 2, image 2 de 2
    • Use your finger or an opening tool to pry the battery out of the phone.
    Demander à FixBot
  3. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Screws: étape 3, image 1 de 1
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
    Demander à FixBot
  4. Samsung Galaxy SIII Mini VE Front Camera Replacement: étape 4, image 1 de 2 Samsung Galaxy SIII Mini VE Front Camera Replacement: étape 4, image 2 de 2
    • Using an opening tool, gently separate the plastic framing from the phone.
    Demander à FixBot
  5. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: étape 5, image 1 de 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: étape 5, image 2 de 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
    Demander à FixBot
  6. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: étape 6, image 1 de 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: étape 6, image 2 de 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: étape 6, image 3 de 3
    • Locate the front camera connection.
    • Using the tweezers, lift the holding tab at the base of the ribbon wire.
    • Again, using the tweezers, gently pull the front camera out and away from the phone.
    Demander à FixBot
2 autres ont terminé cette réparation.
Megan
Membre depuis le 10/23/14
1 255 Réputation
6 tutoriels rédigés
Équipe
Michigan Tech, Team 1-8, Lauer Fall 2014 Membre de l'équipe Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 membres
18 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 31
Total : 1,493
