Introduction
Using these steps, you can replace the volume button on your Galaxy SIII Mini VE.
Ce dont vous avez besoin
Flip your phone so you are facing the back.
Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
Use your finger or an opening tool to pry the battery out of the phone.
Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
Outil utilisé dans cette étape :Tweezers$4.99
Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
Next, use the spudger and tweezers to remove the speaker at the top of the phone.
Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
Detach this connection using the spudger.
Locate the volume button.
Using the tweezers, life the volume button up and away from the phone.
3 autres ont terminé cette réparation.
