Aller au contenu principal
Samsung Galaxy Tab 2 7.0 Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: étape 1, image 1 de 1
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: étape 2, image 1 de 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: étape 3, image 1 de 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: étape 4, image 1 de 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: étape 4, image 2 de 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: étape 4, image 3 de 3
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: étape 5, image 1 de 1
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
2 autres ont terminé cette réparation.
Katija Tarailo
Membre depuis le 03/02/17
460 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S3-G1, Harley Spring 2017 Membre de l'équipe IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 672
