Aller au contenu principal
Samsung Galaxy Tab 3 10.1 Charger Port Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Samsung Galaxy Tab 3 10.1 Charger Port Replacement, Charger Port: étape 1, image 1 de 2 Samsung Galaxy Tab 3 10.1 Charger Port Replacement, Charger Port: étape 1, image 2 de 2
    • Turn off the power to the device before removing the back case.
    • Use a plastic tool to release the screen from the plastic case.
  2. Samsung Galaxy Tab 3 10.1 Charger Port Replacement: étape 2, image 1 de 2 Samsung Galaxy Tab 3 10.1 Charger Port Replacement: étape 2, image 2 de 2
    • Disconnect the battery using a spudger. Pry up gently on both sides to release the connector (marked in green).
    • Remove the tape covering the zif connector (marked in red)
  3. Samsung Galaxy Tab 3 10.1 Charger Port Replacement: étape 3, image 1 de 1
    • Disconnect the cable on the left of the charger (marked in green).
    • Remove the two philips screws that secure the charger port in place (marked in red).
16 autres ont terminé cette réparation.
Harvey
Membre depuis le 02/15/16
5 235 Réputation
10 tutoriels rédigés
5 commentaires
Where would I purchase the charger port and what is the tell tale sign that the charger port is the problem.
Do you know how much this part is
Kind regards
Victoria
Victoria Watson - Réponse
Normally you can find it online at any electronics parts supplier......or eBay. the part itself isn't too expensive but will depend which country you live in.
Harvey - Réponse
Step 3 How do you disconnect the cable from the charge port?
shaneflavell - Réponse
I have replaced the charger, but I have the problem that loads very slowly or the computer does not reconkce the tablet
Edwin Chévez - Réponse
It could be the charger port is defective, even though it is new.
Have you tried another charger cable and plug? It will charge quicker over mains power than over USB charging.
If the computer doesn’t recognize it either, then I would guess that the new part is probably defective, if it was recognized with the old part before.
Harvey -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 9,565
