Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
Remove the camera by gently pulling upward with a pair of tweezers.
