Aller au contenu principal
Samsung Galaxy Tab 3 8.0 Rear Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Battery - Open up the tablet: étape 1, image 1 de 2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Battery - Open up the tablet: étape 1, image 2 de 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Back Cover: étape 2, image 1 de 2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Back Cover: étape 2, image 2 de 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Battery: étape 3, image 1 de 2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Battery: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove Battery: étape 4, image 1 de 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Speakers: étape 5, image 1 de 2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect Speakers: étape 5, image 2 de 2
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: étape 6, image 1 de 3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: étape 6, image 2 de 3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Speakers: étape 6, image 3 de 3
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
  7. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect All Relays: étape 7, image 1 de 2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect All Relays: étape 7, image 2 de 2
    • Using the plastic remover tool carefully unseat the four rectangular electric leads from the board. Each rectangle is a different size, the first one is large, the second one is medium, and the last two are small.
    • Using the plastic remover tool carefully unseat the square electric lead (marked in orange) from the board.
    • Using the plastic remover tool carefully unseat the small square and the two rectangular electric leads (marked in yellow) from the board.
  8. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: étape 8, image 1 de 3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: étape 8, image 2 de 3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Unscrew Motherboard: étape 8, image 3 de 3
    • Unscrew the one 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  9. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove the Motherboard: étape 9, image 1 de 2 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Remove the Motherboard: étape 9, image 2 de 2
    • Carefully lift the board from the device.
  10. Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: étape 10, image 1 de 3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: étape 10, image 2 de 3 Samsung Galaxy Tab 3 8.0 Rear Camera Replacement, Disconnect the Rear Camera: étape 10, image 3 de 3
    • Flip the motherboard to reveal the rear camera connection and with tweezers gently lift the connector pins and remove the camera.
4 autres ont terminé cette réparation.
anthony gonzalez
Membre depuis le 09/22/14
313 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 membres
26 tutoriels rédigés
Un commentaire
That worked a treat, thanks a lot Anthony, I don’t quite know when I broke my rear camera but I suspect it’s after being dropped, unfortunatly more than once, a replacement camera was sourced from ebay and only cost £3.29 that included the postage! So all is well again now.
Here’s a link to where I bought mine, I can recommend them 100%
https://www.ebay.co.uk/itm/Genuine-Rear-...
Once again, Cheers!
mooog1 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 20
Total : 1,380
