Introduction
This guide will walk you through how to replace the Camera in your Samsung Galaxy Tab 3 Lite. To do this, you'll need to remove the back case of your tablet beforehand. The guide for that is listed here as well. Follow all instructions carefully, and take your time.
Ce dont vous avez besoin
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
This is a long process, so don't try and rush it. Also, be careful about applying pressure.
Flip the motherboard over and locate the camera in the middle.
Use the plastic opening tool to gently lift up the flap holding the camera cable in place.
3 autres ont terminé cette réparation.
