Introduction
When the home button is over-pressed or the connecting chip of home button stopped working then for effective functionality of your tablet, you need to replace your home button.
Follow these easy step by step procedure to replace your home button of Samsung Galaxy tab 4 7.0 (model 231) android tablet.
Before beginning, make sure to power off your tablet completely and disconnect from any external power source.
Ce dont vous avez besoin
Using a plastic opening tool, pry open the back case by inserting the tool into the seam and moving it in the gap between front and back panel of the tablet.
Insert triangle opening picks into the gaps as you work to keep the back panel separated.
Outil utilisé dans cette étape :Plastic Cards$2.99
To remove the digitizer, insert and move a plastic opening pick to create a gap between the digitizer and screen.
Carefully lift up the digitizer a little bit and insert a plastic opening card to separate the digitizer from the screen.
2 commentaires
Where can we buy the correct home button?
