Introduction
If your rear camera is taking blurry pictures or otherwise not working properly, it may need to be replaced. This guide will demonstrate how to replace the rear-facing camera.
Ce dont vous avez besoin
Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
Flip the motherboard over to view the back side.
Locate the rear-facing camera on the motherboard.
