Aller au contenu principal
Introduction
Battery life is crucial to maximizing your tablet's utility. This guide will show you the step by step replacement of the Samsung Galaxy Tab 4 8.0 battery. Although replacement is fairly easy, if your tablet's battery has more adhesive than usual, extra force will be needed.
  1. Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off. At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim. Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel. As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. To avoid damaging the screen, gently set the tablet with the LCD screen faced down. Firmly grasp the back plastic casing and lift it away from the front assembly panel.
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).” Remove the sticker to form a tab. Remove the sticker to form a tab.
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  5. Using your thumb and index finger, pinch the tab and pull  it up to remove the top right corner of the battery from the front panel assembly.
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  6. Starting at the bottom left side of the battery, gently remove the green tape. Salvage the green tape if the replacement battery does not include one.
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  7. Run the spudger under the battery to disconnect the red and blue cable connector from the circuit. Lift the battery towards you, away from the front panel. Lift the battery towards you, away from the front panel.
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
14 autre(s) ont terminé cette réparation.
Ofelia Cruz
Membre depuis le 14/09/2015
969 Réputation
5 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-3, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 membres
12 tutoriels rédigés
Everything in this guide looks pretty good. The only thing I would add to step one is to make sure you remove both the SIM card and the Micro SD card. Failure to do so can result in a broken SIM/SD card, slot or board they are connected to.
Cameron - Réponse
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
Jason Stephens - Réponse
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
Carlos Blanquer Bogacz - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 58
Total : 23,955
