Aller au contenu principal
Samsung Galaxy Tab 4 8.0 Verizon Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: étape 1, image 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: étape 1, image 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: étape 1, image 3 de 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 2, image 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 2, image 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 2, image 3 de 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 3, image 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 3, image 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 3, image 3 de 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 4, image 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 4, image 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 4, image 3 de 3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 5, image 1 de 1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 6, image 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 6, image 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 7, image 1 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 7, image 2 de 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 7, image 3 de 3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 8, image 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 8, image 2 de 2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 9, image 1 de 1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 10, image 1 de 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 10, image 2 de 2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Speaker: étape 11, image 1 de 1
    • Insert the opening tool tip into the crack between the speaker and device.
  12. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: étape 12, image 1 de 1
    • Gently pry up on the speaker to disconnect the speaker from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 135
