Aller au contenu principal
Samsung Galaxy Tab 8.9 Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 2, image 1 de 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 3, image 1 de 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 4, image 1 de 1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: étape 5, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: étape 5, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: étape 5, image 3 de 3
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 6, image 1 de 2 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 6, image 2 de 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 7, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 7, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 7, image 3 de 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: étape 8, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: étape 8, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: étape 8, image 3 de 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 9, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: étape 10, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: étape 10, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: étape 10, image 3 de 3
    • Use a spudger to lift up and separate the battery from its housing.
  11. Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: étape 11, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: étape 11, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: étape 11, image 3 de 3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  12. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 12, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 12, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 12, image 3 de 3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  13. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 13, image 1 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 13, image 2 de 3 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 13, image 3 de 3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  14. Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 14, image 1 de 2 Samsung Galaxy Tab 8.9 Motherboard Replacement: étape 14, image 2 de 2
    • Pull away the motherboard from the housing.
4 autres ont terminé cette réparation.
Aleezee True
Membre depuis le 09/30/14
532 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 11-4, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 2,313
