Introduction
If the glass on the screen of your Samsung Galaxy Tab A 9.7 is cracked or damaged in any way, your device could be nearly unusable. This guide will help you replace the display glass in an easy and safe way.
Ce dont vous avez besoin
Microwave the iOpener for 30 seconds.
Place the iOpener on each side of the screen for 30 seconds.
2 autres ont terminé cette réparation.
4 commentaires
incomplete.
Not a good tutorial.
The following steps are completely missing:
- remove the backcover with a pick or Spudger running between back cover and body.
- flip up the lock for the flex cable with a spudger
- slide the flex cable through the body and remove the display
- slide the flex cable of a new display throught the body to the backside
- connect the flex cable to the connector (be aware of correct aligning) and flip down the lock
- glue the display back to the body (do not use much pressure as it may crack the new display!)
- clip back on the back cover
