Aller au contenu principal
Samsung Galaxy Tab A Earphone Jack Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab A Earphone Jack Replacement, Earphone Jack: étape 1, image 1 de 1
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Earphone Jack Replacement: étape 2, image 1 de 2 Samsung Galaxy Tab A Earphone Jack Replacement: étape 2, image 2 de 2
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Earphone Jack Replacement: étape 3, image 1 de 2 Samsung Galaxy Tab A Earphone Jack Replacement: étape 3, image 2 de 2
    • Use the spudger to disconnect the earphone jack from the motherboard.
    • To prevent any damage to either the earphone jack or motherboard, it is recommend to remove the jack at its blue rubber portion.
    • The connected and disconnected earphone jack is shown in the first and second picture, respectively.
  4. Samsung Galaxy Tab A Earphone Jack Replacement: étape 4, image 1 de 2 Samsung Galaxy Tab A Earphone Jack Replacement: étape 4, image 2 de 2
    • Use the PH0 screwdriver bit to remove the 2.5 mm screws attaching earphone jack to the rest of the device.
    • The second picture shows this process in action.
  5. Samsung Galaxy Tab A Earphone Jack Replacement: étape 5, image 1 de 3 Samsung Galaxy Tab A Earphone Jack Replacement: étape 5, image 2 de 3 Samsung Galaxy Tab A Earphone Jack Replacement: étape 5, image 3 de 3
    • Use the spudger to fully remove the earphone jack from the rest of the device.
    • The second picture shows what the device should look like once the earphone jack has been removed.
3 autres ont terminé cette réparation.
Michael Wozny
Membre depuis le 02/04/16
3 738 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-4, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G4
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 5,422
