Aller au contenu principal
Samsung Galaxy Tab E 8.0 Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: étape 1, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: étape 2, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: étape 2, image 2 de 2
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: étape 3, image 1 de 3 Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: étape 3, image 2 de 3 Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: étape 3, image 3 de 3
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: étape 4, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: étape 4, image 2 de 2
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Screen Replacement: étape 5, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement: étape 5, image 2 de 2
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Screen Replacement: étape 6, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement: étape 6, image 2 de 2
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Screen Replacement: étape 7, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement: étape 7, image 2 de 2
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Screen Replacement: étape 8, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement: étape 8, image 2 de 2
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Screen Replacement: étape 9, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement: étape 9, image 2 de 2
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
  10. Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: étape 10, image 1 de 3 Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: étape 10, image 2 de 3 Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: étape 10, image 3 de 3
    • Use the tweezers to lift the flap on the left end of the battery and pull up with your hand to remove the battery.
    • The battery is held by an adhesive on the back, so it will take some force to remove.
  11. Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: étape 11, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: étape 11, image 2 de 2
    • Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
    • Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
    • The metal spudger may be needed to get between the screen.
    • The metal spudger may cause more damage to the screen if used with force.
  12. Samsung Galaxy Tab E 8.0 Screen Replacement: étape 12, image 1 de 2 Samsung Galaxy Tab E 8.0 Screen Replacement: étape 12, image 2 de 2
    • Use the metal spudger to get between the device and the internal screen.
    • Pry out the screen from the device.
6 autres ont terminé cette réparation.
Christian Bloemhof
Membre depuis le 10/08/18
1 102 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S13-G4, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
4 membres
8 tutoriels rédigés
Un commentaire
I am working on a 7” lite E. Is the procedure about the same?
George Tedrick - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 43
Total : 8,945
