Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement
Ce dont vous avez besoin
    1. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement, Camera Replacement: étape 1, image 1 de 2 Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement, Camera Replacement: étape 1, image 2 de 2
      Outil utilisé dans cette étape :
      • Place the Tablet on a flat surface
      • Gather the required tools: iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 2, image 1 de 1
      • Place suction handle in the center of the screen. Firmly press it downwards.
      • This is done to help assist lifting the screen once the edges are loose.
      Demander à FixBot
    3. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 3, image 1 de 1
      • Grab the iFixit opening tool and wedge the sharp end into the corner of the screen. Pry it upwards, lifting up the corner of the screen.
      Demander à FixBot
    4. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 4, image 1 de 1
      • Place the iFixit opening pick between the lifted corner and the housing to prevent the screen from falling back into the housing.
      Demander à FixBot
    5. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 5, image 1 de 1
      • Continue around the perimeter of the screen until you have placed the picks in each remaining corner.
      • Be careful removing the double-sided tape while lifting the screen so that the screen does not break.
      Demander à FixBot
    6. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 6, image 1 de 1
      • Grab the suction handle and gently lift the screen towards the top of the tablet.
      • Take care while lifting the screen to avoid damaging the ribbon cable at the top of the tablet.
      Demander à FixBot
    7. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 7, image 1 de 1
      • Place the removed screen that is still attached to the ribbon cable flat on the table.
      Demander à FixBot
    8. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 8, image 1 de 1
      • Grab the iFixit opening tool and wedge the sharp end into the corner of the housing and pry upwards.
      • Place an iFixit opening pick between the housing and the LCD assembly.
      Demander à FixBot
    9. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 9, image 1 de 1
      • Continue along the outer edge of the housing until you have placed an iFixit opening pick in each corner.
      Demander à FixBot
    10. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 10, image 1 de 1
      • Remove the LCD assembly from the housing and place it face down on the table.
      Demander à FixBot
    11. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 11, image 1 de 1
      • Locate the ribbon cable connector on the back of the LCD assembly.
      • Use the spudger to pry the ZIF connector lock tab upwards.
      • Pull the the ribbon cable to remove it from the connector.
      Demander à FixBot
    12. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 12, image 1 de 1
      • Use the curved precision tweezers and carefully peel off the protective green film on top of the camera connector.
      Demander à FixBot
    13. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 13, image 1 de 1
      • Use the spudger and gently pry the ZIF connector lock tab upwards, releasing the ribbon cable.
      Demander à FixBot
    14. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: étape 14, image 1 de 1
      • Grab the camera and pull up and away from the connector.
      Demander à FixBot
2 autres ont terminé cette réparation.
Matthew Skoog
Membre depuis le 05/22/19
250 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S4-G4, Wilson Summer 2019 Membre de l'équipe IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 membres
48 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 37
Total : 981
