Aller au contenu principal
Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement, Digitizer (Screen Replacement): étape 1, image 1 de 2 Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement, Digitizer (Screen Replacement): étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Place the Tablet on a flat surface.
    • Gather the required tools : iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
  2. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 2, image 1 de 1
    • Place suction handle in the center of the screen. Firmly press it downwards .
    • This is done to help assist lifting the screen once the edges are loose.
  3. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 3, image 1 de 1
    • Grab the iFixit pening tool and wedge the sharp end into the corner of the screen. Pry it upwards, lifting up the corner of the screen.
  4. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 4, image 1 de 1
    • Place the iFixit opening pick between the lifted corner and the housing to prevent the screen from falling back into the housing.
  5. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 5, image 1 de 1
    • Continue around the perimeter of the screen until you have placed the picks in each remaining corner.
    • Be careful removing the double-sided tape while lifting the screen so that the screen does not break.
  6. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 6, image 1 de 1
    • Grab the suction handle and gently lift the screen towards the top of the tablet.
    • Take care while lifting the screen to avoid damaging the ribbon cable at the top of the tablet.
  7. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 7, image 1 de 1
    • Place the removed screen that is still attached to the ribbon cable flat on the table.
  8. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 8, image 1 de 1
    • Grab the iFixit opening tool and wedge the sharp end into the corner of the housing and pry upwards.
    • Place an iFixit opening pick between the housing and the LCD assembly.
  9. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 9, image 1 de 1
    • Continue along the outer edge of the housing until you have placed an iFixit opening pick in each corner.
  10. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 10, image 1 de 1
    • Remove the LCD assembly from the housing and place it face down on the table.
  11. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 11, image 1 de 1
    • Locate the ribbon cable connector on the back of the LCD assembly.
    • Use the spudger to pry the connector tab upwards.
    • Pull the the ribbon cable to remove it from the connector
  12. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: étape 12, image 1 de 1
    • Once the ribbon cable is removed, pull the screen off of the motherboard and place it to the side.
6 autres ont terminé cette réparation.
Juelma
Membre depuis le 05/22/19
253 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S4-G4, Wilson Summer 2019 Membre de l'équipe IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 44
Total : 5,336
