Aller au contenu principal
Samsung Galaxy Tab E Lite 7 Kids Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: étape 1, image 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: étape 1, image 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: étape 1, image 3 de 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 2, image 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 2, image 2 de 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: étape 3, image 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: étape 3, image 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: étape 3, image 3 de 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 4, image 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 5, image 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 6, image 1 de 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 8, image 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 8, image 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Camera: étape 9, image 1 de 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Camera: étape 9, image 2 de 2
    • Flip the motherboard over.
    • Use a plastic opening tool to lift up the latch holding the camera cable.
  10. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 10, image 1 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 10, image 2 de 3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: étape 10, image 3 de 3
    • Pull the ribbon cable and the camera.
Jordan Bermudez
Membre depuis le 02/17/17
285 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S19-G2, Hoffman Spring 2017 Membre de l'équipe USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 338
