Introduction
Are you photos looking strange? Is the camera on the back panel scratched or cracked? Replacing the back panel camera should fix the problem.
Ce dont vous avez besoin
Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
Remove strip of green tape covering the camera connector with the tweezers.
