Introduction
This guide will show the process behind replacing a daughterboard in the Samsung Galaxy Tab S3. This will be useful for fixing a broken charging port, as the port is soldered onto the daughterboard. It would also be useful if the home button, auxiliary, charging port and left speaker simultaneously stopped working, as these components all filter communications through the daughterboard to the motherboard for processing.
Ce dont vous avez besoin
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
Outil utilisé dans cette étape :Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Use a spudger to pry up four press fit connectors from the lower board containing the charging port.
3 autres ont terminé cette réparation.
3 commentaires
Do you need to remove the front display assembly to replace the daughterboard? From the images it appears you just have to go in through the back glass to do this job. Confused.
You do, because the midframe is adhered to both the front and back. It won't come off if you just take off the back.
You don't have to take screen off. Just disconnect battery.
There is no reason to remove the screen while replacing a battery.
Nick Youngstrom - Réponse
Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
Phenix City - Réponse
