Aller au contenu principal
Samsung Galaxy TabPro S Front-Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: étape 1, image 1 de 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: étape 1, image 2 de 2
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 2, image 1 de 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 3, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 4, image 1 de 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 4, image 2 de 2
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 5, image 1 de 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: étape 5, image 2 de 2
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
Mitchell Caister
Membre depuis le 03/31/22
328 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-4, Harley Spring 2022 Membre de l'équipe IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 265
