Aller au contenu principal
Samsung Galaxy Victory 4G Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: étape 2, image 1 de 1
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: étape 3, image 1 de 1
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: étape 4, image 1 de 1
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: étape 5, image 1 de 3 Samsung Galaxy Victory 4G Motherboard Replacement: étape 5, image 2 de 3 Samsung Galaxy Victory 4G Motherboard Replacement: étape 5, image 3 de 3
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: étape 6, image 1 de 2 Samsung Galaxy Victory 4G Motherboard Replacement: étape 6, image 2 de 2
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
6 autres ont terminé cette réparation.
Zhao
Membre depuis le 09/23/14
251 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 15-3, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 1,612
