Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy XCover Pro Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy XCover Pro Motherboard Replacement, Screen: étape 1, image 1 de 1
    • Using a heat gun, or a hair dryer on high, heat the screen, focusing on the edges around the screen to melt the glue holding the screen on.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy XCover Pro Motherboard Replacement: étape 2, image 1 de 1
    • After heating, insert picks around the barrier of the screen as wedges to help with pulling the screen off.
    • The screen will begin to pry off with the picks inserted; however, a suction cup can be used to assist in separating the screen from the casing.
    Demander à FixBot
  3. Samsung Galaxy XCover Pro Motherboard Replacement: étape 3, image 1 de 2 Samsung Galaxy XCover Pro Motherboard Replacement: étape 3, image 2 de 2
    • Unclip the black tab covering the motherboard and screen ribbon cables.
    Demander à FixBot
  4. Samsung Galaxy XCover Pro Motherboard Replacement: étape 4, image 1 de 2 Samsung Galaxy XCover Pro Motherboard Replacement: étape 4, image 2 de 2
    • Use a spudger or tweezers to pull the ribbon connecting the screen to the device, disconnecting it entirely.
    Demander à FixBot
  5. Samsung Galaxy XCover Pro Motherboard Replacement, Motherboard: étape 5, image 1 de 2 Samsung Galaxy XCover Pro Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Remove the ribbon cable connecting the charging port board (bottom) and the motherboard (top).
    Demander à FixBot
  6. Samsung Galaxy XCover Pro Motherboard Replacement: étape 6, image 1 de 3 Samsung Galaxy XCover Pro Motherboard Replacement: étape 6, image 2 de 3 Samsung Galaxy XCover Pro Motherboard Replacement: étape 6, image 3 de 3
    • Remove the fourteen 4 mm screws holding down the backplate using a Phillips #000 screwdriver.
    • Use an opening tool to remove the backplate.
    Demander à FixBot
  7. Samsung Galaxy XCover Pro Motherboard Replacement: étape 7, image 1 de 3 Samsung Galaxy XCover Pro Motherboard Replacement: étape 7, image 2 de 3 Samsung Galaxy XCover Pro Motherboard Replacement: étape 7, image 3 de 3
    • Using an opening tool, disconnect the red and blue wires from the motherboard.
    • Disconnect the headphone jack and side button ribbon cables that are both connected to the motherboard.
    Demander à FixBot
  8. Samsung Galaxy XCover Pro Motherboard Replacement: étape 8, image 1 de 2 Samsung Galaxy XCover Pro Motherboard Replacement: étape 8, image 2 de 2
    • Remove the two 2.4 mm screws from the motherboard using a Phillips #000 screwdriver.
    • Remove the motherboard with an opening tool or your finger.
    Demander à FixBot
Kristen Gismondi
Membre depuis le 11/12/14
107 782 Réputation
270 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 58
Total : 145
