Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Y Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Y Motherboard Replacement, Back Panel: étape 1, image 1 de 3 Samsung Galaxy Y Motherboard Replacement, Back Panel: étape 1, image 2 de 3 Samsung Galaxy Y Motherboard Replacement, Back Panel: étape 1, image 3 de 3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Y Motherboard Replacement, Motherboard: étape 2, image 1 de 3 Samsung Galaxy Y Motherboard Replacement, Motherboard: étape 2, image 2 de 3 Samsung Galaxy Y Motherboard Replacement, Motherboard: étape 2, image 3 de 3
    • Use a Phillips #000 screwdriver to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of its slot.
    Demander à FixBot
  3. Samsung Galaxy Y Motherboard Replacement: étape 3, image 1 de 2 Samsung Galaxy Y Motherboard Replacement: étape 3, image 2 de 2
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
    Demander à FixBot
  4. Samsung Galaxy Y Motherboard Replacement: étape 4, image 1 de 3 Samsung Galaxy Y Motherboard Replacement: étape 4, image 2 de 3 Samsung Galaxy Y Motherboard Replacement: étape 4, image 3 de 3
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
    Demander à FixBot
  5. Samsung Galaxy Y Motherboard Replacement: étape 5, image 1 de 3 Samsung Galaxy Y Motherboard Replacement: étape 5, image 2 de 3 Samsung Galaxy Y Motherboard Replacement: étape 5, image 3 de 3
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
    Demander à FixBot
Peggi Trask
Membre depuis le 09/21/18
109 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 35
Total : 1,368
