Aller au contenu principal
Samsung Gear 2 Neo Display Replacement
Ce dont vous avez besoin
  1. Samsung Gear 2 Neo Display Replacement, Battery: étape 1, image 1 de 1
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Display Replacement: étape 2, image 1 de 2 Samsung Gear 2 Neo Display Replacement: étape 2, image 2 de 2
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Display Replacement: étape 3, image 1 de 1
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Display Replacement: étape 4, image 1 de 2 Samsung Gear 2 Neo Display Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
  5. Samsung Gear 2 Neo Display Replacement, Motherboard: étape 5, image 1 de 1
    • Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
  6. Samsung Gear 2 Neo Display Replacement: étape 6, image 1 de 1
    • It is recommended to use antistatic wrist wrap whenever removing the motherboard.
    • Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
    • Attached to the motherboard is the infrared LED Light. To replace the IR LED, you may need to replace the entire motherboard.
  7. Samsung Gear 2 Neo Display Replacement, Display: étape 7, image 1 de 1
    • Use the spudger and apply pressure to the back of the AMOLED display.
    • Make sure to stay within the area marked to avoid damaging the device.
  8. Samsung Gear 2 Neo Display Replacement: étape 8, image 1 de 1
    • Once part of the display begins detaching from the front cover, place the spduger in between the display and the front cover.
  9. Samsung Gear 2 Neo Display Replacement: étape 9, image 1 de 1
    • Use the spudger to scrape off the adhesive located on the bottom side of the display, attaching the display to the front cover.
    • Be careful when doing this step as it could potentially break the display and/or the case if not followed properly.
  10. Samsung Gear 2 Neo Display Replacement: étape 10, image 1 de 1
    • After the adhesive has been removed, apply pressure with the spudger to the back of the AMOLED display; the display should pop right out.
5 autres ont terminé cette réparation.
Victor Yore
Membre depuis le 08/27/15
705 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 5-6, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 6,123
