Introduction
If your Infrared stops working, your devices' RAM isn't functioning, or if the core of the Gear 2 Neo stops working then this guide will help in replacing the motherboard which have each of these integrated into it. This has a difficulty of 3 out of 10, and should only take about 5 minutes to complete.
Pièces
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
