Aller au contenu principal
Samsung Gear S3 Frontier Bezel Ring Replacement
Ce dont vous avez besoin
  1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: étape 1, image 1 de 3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: étape 1, image 2 de 3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: étape 1, image 3 de 3
    • Contains small springs and ball bearings. We suggest working over a plate or tray.
    • Hold the watch firmly in one hand, face up.
    • Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
    • The plastic retainer is manufactured with an open gap, you did not break it.
    • For reassembly, set the plastic retainer in the ring, then press the ring down until it snaps in place.
26 autres ont terminé cette réparation.
Mark Iknoian
Membre depuis le 10/08/18
1 027 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S15-G2, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 membres
34 tutoriels rédigés
42 commentaires
I got the bezel popped off to clean it. Now it wont pop back on! Help!
shileski - Réponse
line up the bezel with the screen and push it in
Arthur -
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
Hardy T - Réponse
did u manage to fix it?
Dave Green - Réponse
Interested to know if anyone had much success with this process.
Seth Armour - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 65
30 derniers jours : 366
Total : 85,850
