Introduction
Si l'écran tactile de votre appareil ne répond pas ou est fissuré, remplacez-le avec ce guide. Pour ce faire, vous devrez remplacer l'ensemble de la vitre avant, car vous ne pouvez pas simplement remplacer l'écran lui-même.
Ce dont vous avez besoin
Placez l'écran de la montre vers le bas de façon à ce que son couvercle arrière soit visible.
Retirer les quatre vis de 4,2 mm à l'aide d'un tournevis Y00.
Did you use iFixit tools? I just checked and I believe Y00 is correct. Y0 slips too easily. My test was with the Y bits from the Pro Tech Toolkit.
I too had to use an Y0 screwdriver (from Ifixit 64 bit driver kit....). Y00 just don't grip, may be some batches of the watch used different screws??
One screw just doesn't want to move, any suggestions/tips how to remove it?
Problem solved: after 2 times of careful WD40 application and blunting the Y00 a bit it came of with a lot of patience.
I also had a problem with one of the screws and flipping to Y0 worked for that one.
Yo use Y 0.6 y anduvo perfecto!!
Yo use Y 0.6 y anduvo perfecto!!!
Coincer la broche métallique entre le couvercle arrière et le cadre le long de la jointure.
Utiliser la force pour éloigner le couvercle arrière du cadre principal de la montre.
Il est plus facile et moins domageable pour le joint de commencer par ouvrir le cache de connexion situé à coté de l’axe du bracelet long. On peut alors glisser la broche sans détériorer le joint, qui est plus éloigné du bord à cet endroit.
I’m pretty sure the seal is equally far away from the edge on all sides.
This was the hardest part. I did use thin flat head screw to dismantle it. Using the metal spudger felt like impossible due to its thickness.
Did using the screwdriver damage the case in any way? I’d recommend being careful using a tool with smaller surface area as that will apply more pressure at the point of entry. As the guide states, a Jimmy may also be used instead of the spudger.
Not sure if it's a gasket or some sort of sealant paste/gel. Just took my case off, and the gasket seems intact (fused to back cover of the watch. Quick search for waterproof sealant yielded lots of possibilities - don't know which one to choose. Can anyone with experience provide advice?
most things I have seen online say use an RTV like permatex black sealant. pretty available at like autozone or o'reilly or walmart.
Ma questa guarnizione impermeabile si puo sostituire ? Come controllare se si è danneggiata? Come evitare che entri acqua dopo averlo aperto ?
Il est préférable d'utiliser, si possible, un outil adapté pour l'ouverture des boîtes de montre.
Avec précaution, le joint n'est pas trop abîmé. Il est distendu. Possibilité de le couper et de le réajuster correctement.
I have used a the Jimmy and I didn't need to do any force at all
Que puedo usar para poner en la tapa y cambias el sellado ya que se me arruinó.
Quiero que vuelva a ser hermético.
Gracias
Détachez les trois connecteurs de la carte mère à l'aide de votre ongle.
Séparer la carte mère et la vitre avant à l'aide d'un spudger.
Oui tuto bien clair. Opération réussi !
Bien qu’adroit de mes mains, et après avoir découvert la “bête à coeur ouvert”, je ne sais pas si je me serais lancé... C’est tout l’interêt de ce Tuto qui invite à le faire (car pas trop de détails), et qui suivit pas à pas permet de s’en sortir. Bravo
Merci Dan.S
Better replace the 2 bolts from next step first.
The guide has you remove the screws second because it makes it possible to remove the whole assembly without snapping any cables.
Ok... Woher bekomme ich die Displayeinheit ???🤷🏻♂️
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
13 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Schwarzer nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
8 commentaires
can you tell me where can i buy the whole front screen ?
Same question, I am having great difficulty in locating the PARTS to complete these repairs. Can someone please list where we can actually purchase the replacement parts that are shown in these guides??
Can anyone please tell, where to get the parts?
Bonjour, ma montre Samsung Galaxy Gear S3 frontier ne fonctionne plus correctement à l'issue d'une exposition prolongée dans la piscine. d'abord elle était bloquée sur "rebooting" puis a fini par s'éteindre. Une semaine après, je l'ia rechargée et rallumée... elle a fonctionné normalement pendant quelques heures puis l'écran s'est mis à scintiller avec un voile coloré... Que faut-il faire pour la réparer ?
