Aller au contenu principal
Samsung Gear VR Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: étape 1, image 1 de 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: étape 1, image 2 de 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: étape 1, image 3 de 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: étape 2, image 1 de 2 Samsung Gear VR  Motherboard Replacement: étape 2, image 2 de 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: étape 4, image 1 de 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
David Forlano
Membre depuis le 09/25/17
119 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 membres
7 tutoriels rédigés
Un commentaire
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 1,551
