Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Gear VR Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: étape 1, image 1 de 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: étape 1, image 2 de 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: étape 1, image 3 de 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Gear VR  Motherboard Replacement: étape 2, image 1 de 2 Samsung Gear VR  Motherboard Replacement: étape 2, image 2 de 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
    Demander à FixBot
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
    Demander à FixBot
  4. Samsung Gear VR  Motherboard Replacement: étape 4, image 1 de 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
    Demander à FixBot
David Forlano
Membre depuis le 09/25/17
119 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 membres
7 tutoriels rédigés
1 commentaire de tutoriel
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 47
Total : 1,946
