Aller au contenu principal
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: étape 1, image 1 de 1
    • Remove front cover from headset.
  2. Samsung Gear VR USB Connector Replacement: étape 2, image 1 de 1
    • Slide the latch to the right to unlock the current connector.
  3. Samsung Gear VR USB Connector Replacement: étape 3, image 1 de 2 Samsung Gear VR USB Connector Replacement: étape 3, image 2 de 2
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
  4. Samsung Gear VR USB Connector Replacement: étape 4, image 1 de 1
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
  5. Samsung Gear VR USB Connector Replacement: étape 5, image 1 de 2 Samsung Gear VR USB Connector Replacement: étape 5, image 2 de 2
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
3 autres ont terminé cette réparation.
Alfredo Aparicio
Membre depuis le 09/25/17
325 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 membres
7 tutoriels rédigés
5 commentaires de tutoriel
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Réponse
Were do I get the USB c adapter
helenpaul77 - Réponse
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron -
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh -
Where can I get micro USB converter for gear vr not type c
Molefi Aaron - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 18
30 derniers jours : 57
Total : 17,007
