Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Gear VR USB Connector Replacement
    1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: étape 1, image 1 de 1
      • Remove front cover from headset.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung Gear VR USB Connector Replacement: étape 2, image 1 de 1
      • Slide the latch to the right to unlock the current connector.
      Demander à FixBot
    3. Samsung Gear VR USB Connector Replacement: étape 3, image 1 de 2 Samsung Gear VR USB Connector Replacement: étape 3, image 2 de 2
      • Lift connector clip away from headset and towards you.
      • Slide current connector out and away from headset until it is disconnected from connector clip.
      Demander à FixBot
    4. Samsung Gear VR USB Connector Replacement: étape 4, image 1 de 1
      • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
      • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
      Demander à FixBot
    5. Samsung Gear VR USB Connector Replacement: étape 5, image 1 de 2 Samsung Gear VR USB Connector Replacement: étape 5, image 2 de 2
      • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
      • Slide the lock latch to the left to secure the connector into place.
      Demander à FixBot
3 autres ont terminé cette réparation.
Alfredo Aparicio
Membre depuis le 09/25/17
325 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 membres
49 tutoriels rédigés
5 commentaires de tutoriel
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Réponse Partager
Were do I get the USB c adapter
helenpaul77 - Réponse Partager
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - Réponse Partager
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - Réponse Partager
Where can I get micro USB converter for gear vr not type c
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 104
Total : 18,298
