Introduction
If the focus wheel on your Samsung Gear VR is not working, use this guide to replace the focus wheel. To complete this replacement, you will need an iFixit opening tool, metal spudger, and Phillips #000 screwdriver head.
Ce dont vous avez besoin
Push the switch on the right-hand side of the device to separate the cover from the main body.
Pull the cover away from the main device.
Remove the one 5mm Phillips #000 screw.
Separate the focus wheel from the headset using your fingers.
