Aller au contenu principal
Samsung Gear VR With Controller Trackpad Replacement
Ce dont vous avez besoin
  1. Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: étape 1, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: étape 1, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: étape 1, image 3 de 3
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR With Controller Trackpad Replacement: étape 2, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 2, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 2, image 3 de 3
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR With Controller Trackpad Replacement: étape 3, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 3, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 3, image 3 de 3
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR With Controller Trackpad Replacement: étape 4, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 4, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 4, image 3 de 3
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR With Controller Trackpad Replacement: étape 5, image 1 de 2 Samsung Gear VR With Controller Trackpad Replacement: étape 5, image 2 de 2
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR With Controller Trackpad Replacement: étape 6, image 1 de 2 Samsung Gear VR With Controller Trackpad Replacement: étape 6, image 2 de 2
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR With Controller Trackpad Replacement: étape 7, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 7, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 7, image 3 de 3
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR With Controller Trackpad Replacement: étape 8, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 8, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement: étape 8, image 3 de 3
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
  9. Samsung Gear VR With Controller Trackpad Replacement, Trackpad: étape 9, image 1 de 3 Samsung Gear VR With Controller Trackpad Replacement, Trackpad: étape 9, image 2 de 3 Samsung Gear VR With Controller Trackpad Replacement, Trackpad: étape 9, image 3 de 3
    • Remove the one 5mm Phillips #000 screw to detach the trackpad from the headset.
    • Pry the trackpad loose from the headset using the spudger.
Jake Criscione
Membre depuis le 01/24/19
587 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S18-G3, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 322
