Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If your phone doesn't have a compatible USB port or if the USB connector breaks, use this guide to swap the connector out for a new one. The Samsung Gear VR can hold a USB Type-C or Micro USB. This guide requires no tools.
  1. Push the switch on the right-hand side of the device to separate the cover from the main body. Pull the cover away from the main device. Pull the cover away from the main device.
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  3. Slide the gray switch to the right to unlock the USB connector. Lift the connector perpendicular to the device. Slide off the USB connector gently with your fingers.
    • Slide the gray switch to the right to unlock the USB connector.
    • Lift the connector perpendicular to the device.
    • Slide off the USB connector gently with your fingers.
Nick Alan Maley
Membre depuis le 29/01/2019
108 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G3, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 178
