Aller au contenu principal
Samsung Gear VR with Controller Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: étape 1, image 1 de 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: étape 1, image 2 de 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: étape 1, image 3 de 3
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: étape 2, image 1 de 3 Samsung Gear VR with Controller Motherboard Replacement: étape 2, image 2 de 3 Samsung Gear VR with Controller Motherboard Replacement: étape 2, image 3 de 3
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: étape 3, image 1 de 2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: étape 3, image 2 de 2
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: étape 4, image 1 de 1
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: étape 5, image 1 de 2 Samsung Gear VR with Controller Motherboard Replacement: étape 5, image 2 de 2
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: étape 6, image 1 de 3 Samsung Gear VR with Controller Motherboard Replacement: étape 6, image 2 de 3 Samsung Gear VR with Controller Motherboard Replacement: étape 6, image 3 de 3
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
2 autres ont terminé cette réparation.
Jake Criscione
Membre depuis le 01/24/19
587 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S18-G3, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 947
