Introduction
After several times of using buttons, they can become stuck or faulty. This guide can be used to loosen or replace the record button.
Ce dont vous avez besoin
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
