Introduction
The battery is located inside the camera. To remove the battery, it will require uninstalling the battery housing. This can be done in a few steps found below.
To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
  • To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
Ajouter un commentaire
Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
  • As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
  • Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
  • Pull the wire ribbon out with a pair of tweezers.
  • To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws.
  • Use the plastic opening tool to pry the battery housing open.
  • After removing the battery housing, take the battery out.
5 autre(s) ont terminé cette réparation.
Robert
Membre depuis le 21/01/2015
909 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 9-2, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 19
Total : 1,261
