Introduction
How to remove & replace the phone's keyboard.
Outils
Pièces
Aucune pièce spécifiée.
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
To free the circuit board, remove the black wire that is holding it down.
Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
The antenna assembly will snap off.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
