Aller au contenu principal
Samsung Instinct Antenna Replacement
Ce dont vous avez besoin
  1. Samsung Instinct Antenna Replacement, Battery: étape 1, image 1 de 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Antenna Replacement: étape 2, image 1 de 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Antenna Replacement, Back Case: étape 3, image 1 de 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Antenna Replacement: étape 4, image 1 de 2 Samsung Instinct Antenna Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Antenna Replacement: étape 5, image 1 de 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Antenna Replacement, Antenna: étape 6, image 1 de 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Antenna Replacement: étape 7, image 1 de 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Antenna Replacement: étape 8, image 1 de 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Antenna Replacement: étape 9, image 1 de 1
    • Gently lift up on the antenna and remove it from the back of the device.
Jimmy Kuo
Membre depuis le 10/10/11
14 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-13, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 1,050
