Aller au contenu principal
Samsung Instinct Front Case Replacement
Ce dont vous avez besoin
  1. Samsung Instinct Front Case Replacement, Battery: étape 1, image 1 de 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Front Case Replacement: étape 2, image 1 de 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Front Case Replacement, Back Case: étape 3, image 1 de 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Front Case Replacement: étape 4, image 1 de 2 Samsung Instinct Front Case Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Front Case Replacement: étape 5, image 1 de 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Front Case Replacement, Antenna: étape 6, image 1 de 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Front Case Replacement: étape 7, image 1 de 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Front Case Replacement: étape 8, image 1 de 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Front Case Replacement: étape 9, image 1 de 1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Front Case Replacement, Front Case: étape 10, image 1 de 1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Front Case Replacement: étape 11, image 1 de 3 Samsung Instinct Front Case Replacement: étape 11, image 2 de 3 Samsung Instinct Front Case Replacement: étape 11, image 3 de 3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Front Case Replacement: étape 12, image 1 de 1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Front Case Replacement: étape 13, image 1 de 2 Samsung Instinct Front Case Replacement: étape 13, image 2 de 2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Front Case Replacement: étape 14, image 1 de 1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Front Case Replacement: étape 15, image 1 de 1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
Jacob Michener
Membre depuis le 10/10/11
31 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-13, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 13
Total : 730
