Introduction
A guide to help replace the spring inside of the setting knob on top of the camera.
Ce dont vous avez besoin
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Remove the screws holding the circuit board.
After you remove the screws, carefully remove the circuit board.
Face the bottom of the Flash Circuit board towards you.
Remove the one screw that's located on the left side of the lens.
