Aller au contenu principal
Samsung LN-T5265F T-Con Board Replacement
Ce dont vous avez besoin
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: étape 1, image 1 de 1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: étape 3, image 1 de 2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: étape 3, image 2 de 2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: étape 4, image 1 de 2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: étape 4, image 2 de 2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: étape 5, image 1 de 1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: étape 6, image 1 de 1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
3 autres ont terminé cette réparation.
Steven Carlton
Membre depuis le 08/19/13
606 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 29
Total : 10,088
