Aller au contenu principal
Samsung Level Box Mini Speakers Replacement
Ce dont vous avez besoin
  1. Samsung Level Box Mini Speakers Replacement, Battery: étape 1, image 1 de 2 Samsung Level Box Mini Speakers Replacement, Battery: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
  2. Samsung Level Box Mini Speakers Replacement: étape 2, image 1 de 1
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Speakers Replacement: étape 3, image 1 de 1
    • Using the plastic opening tool, remove the batteries from the device.
  4. Samsung Level Box Mini Speakers Replacement, Speakers: étape 4, image 1 de 2 Samsung Level Box Mini Speakers Replacement, Speakers: étape 4, image 2 de 2
    • Remove the speaker grill from the device.
  5. Samsung Level Box Mini Speakers Replacement: étape 5, image 1 de 1
    • Remove the six 2.5 mm Philips #2 screws on the front of the device surrounding the speakers using the Screwdriver PH2 Philips Head.
  6. Samsung Level Box Mini Speakers Replacement: étape 6, image 1 de 3 Samsung Level Box Mini Speakers Replacement: étape 6, image 2 de 3 Samsung Level Box Mini Speakers Replacement: étape 6, image 3 de 3
    • Remove the eight 1.6 mm Philips #1 screws from the sides, front, and back of the device using the Screwdriver J000 Philips Head.
  7. Samsung Level Box Mini Speakers Replacement: étape 7, image 1 de 2 Samsung Level Box Mini Speakers Replacement: étape 7, image 2 de 2
    • Gently tap the back of the device to remove the speakers.
  8. Samsung Level Box Mini Speakers Replacement: étape 8, image 1 de 1
    Anti-Static Wrist Strap
    $7.95
  9. Samsung Level Box Mini Speakers Replacement: étape 9, image 1 de 1
    • To put the replacement speakers onto the device, use a soldering tool to solder the wires onto the new speakers.
6 autres ont terminé cette réparation.
Amanda Hymer
Membre depuis le 02/16/17
657 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Kass Spring 2017 Membre de l'équipe USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 membres
4 tutoriels rédigés
2 commentaires
Só tem esse video que mostra passo a passo como desmontar o Samsung Level Box Mini.
Obrigado por compartilhar amigo, espero que esse video ajude outras pessoas.
saulo_venancio - Réponse
Samsung seviye kutusu mini ses gürültüsünü engelleyen hoparlörler, devreden çok yüksek perdeli bir ses alıyorum.
Alaybeyi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 34
Total : 4,889
