Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will require the user to disassemble the rear and top panel to access the button.
Pièces
Aucune pièce spécifiée.
  1. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
    • Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
  2. Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2  screws on the back of the printer.
    • Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
  3. Gently lift the top panel while simultaneously pulling off the back panel. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  5. Remove front panel by gently moving the holes on the panel from the pegs attached to the main printer body, one at a time. Remove front panel by gently moving the holes on the panel from the pegs attached to the main printer body, one at a time. Remove front panel by gently moving the holes on the panel from the pegs attached to the main printer body, one at a time.
    • Remove front panel by gently moving the holes on the panel from the pegs attached to the main printer body, one at a time.
  6. Using a Phillips #2 screwdriver, remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
    • Using a Phillips #2 screwdriver, remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
  7. Using a plastic opening tool, gently lift one side of the top panel from its peg. Repeat for the other side. Lift the top panel from the front to remove entirely.
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat for the other side.
    • Lift the top panel from the front to remove entirely.
    • Turn over the top panel to reveal the underside, revealing the button.
  8. Using a Phillips #2 screwdriver, remove the two, 1", Phillips, PH#2 screws from the underside of the top panel
    • Using a Phillips #2 screwdriver, remove the two, 1", Phillips, PH#2 screws from the underside of the top panel
  9. Remove the clear plastic piece and the orange button from the panel. Remove the orange button and the spring from the clear plastic piece.
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic piece.
    • Replace the button and reassemble the printer following the directions in reverse order.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
bbaustin
Membre depuis le 12/10/2011
247 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-18, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,653
